Mikasa 1902 with Pontos 1/200th.
KitMaker: 6,816 posts
Model Shipwrights: 6,387 posts
Posted: Tuesday, January 08, 2019 - 07:25 AM UTC
Last weekend's progress. (more etch)
The torpedo net boom mounts. The first mount assembled.
The first couple in place.
all sixteen done.
The first section of the net shelves assembled and ready for fitting.
Fitting the port side net shelves.
The first of the crutches for booms on place.
Not quite half way round, so a couple more sessions before I can think about paint.
KitMaker: 1,650 posts
Model Shipwrights: 1,042 posts
Posted: Tuesday, January 08, 2019 - 12:38 PM UTC
Even at 1/200 scale those net shelves had to quite a challenge to get on straight, hats off to fine job.
Posted: Tuesday, January 08, 2019 - 08:46 PM UTC
Thanks you Mark,
It is "fun", fortunately there is one useful aid, the support struts sit on a join in the plating, so t least I have something to try and line up on.
Not quite half way yet.
KitMaker: 3,491 posts
Model Shipwrights: 2,586 posts
Posted: Tuesday, January 08, 2019 - 09:34 PM UTC
Some very fine work going on here Si
Staggering amount of AM on this kit if memory serves
Posted: Wednesday, January 09, 2019 - 05:31 AM UTC
Staggering is one word for it, I reckon there will be at least 300 etched parts on the hull before it gets paint on it.
KitMaker: 4,379 posts
Model Shipwrights: 193 posts
Posted: Wednesday, January 09, 2019 - 07:48 AM UTC
And excellent job on those torpedo net parts! Trying to get those support legs on right would have driven me mad. Did you use regular CA?
I'm curious to see how the nets were kitted.
Great progress!
Posted: Wednesday, January 09, 2019 - 08:41 PM UTC
Great progress!
Thanks Gaz,
I used a Gel CA, as it grips a little more quickly.
I must admit, they made me a little nervous and I very nearly did wimp out and use the kit parts. The kit parts are simplified, consisting of three sections per side with the supports just needing to be folded down. I am sure they would look great in place, and that was the back up if I mucked these up.
Usual great Pontos design, I will add a picture of the next section showing the parts prior to assembly, it will be easier than trying to describe it. suffice to say it makes it easy to get the supports straight.
Pontos provide etched extended nets, nothing for stowed either in the kit or the Pontos set. I will be using the extended nets, because they are there.
Thanks for looking in mate.
Posted: Thursday, January 10, 2019 - 10:28 PM UTC
The extended nets should be a real eye-catcher! And I'd be real keen to see some of your parts in-the-making.
In 1/350 scale, I know of some who have used shoe laces for the stowed nets with varying degrees of success. I've done an experiment with some nylons to try to get more of a mesh look. I still haven't had what I'd call real success. I sometimes wonder if there are just some things that can't be minimized enough.
Posted: Friday, January 11, 2019 - 01:59 AM UTC
Hi Gaz,
Apologies mate, but you may have a little wait, the booms and the nets will be going on last. I have to say what Pontos provide looks quite outstanding on the fret.
Stowed nets are tricky, I tried have nylons myself but the mesh is generally too fine and they ware way too soft. Shoelaces can work ok in 1/700th. If you can get hold of fine plastic mesh, the sort of stuff used in strainers quite stiff but it can be rolled and lashed. It is not easy in find in sheets on this side of the pond, but some smaller hardware stores may carry it.
Posted: Friday, January 11, 2019 - 08:08 AM UTC
This week's progress.
The basic parts of the net shelf.
The section assembled.
The starboard bow section is slightly different from the port, with a gap between two section.
A slight flaw in the construction, it doesn't look too bad with the Mk1 eyeball.
The starboard side all fitted out with net shelves and gear for the booms.
One small job before the Admirals walk, racks for the stream anchors. There are kit parts provided for this, do the holes need filling.
And the racks in place.
Work started on the Admiral's walk.
The underside structure underway.
That just needs some etched struts and then it can be fitted, then it is paint time.
si
Posted: Saturday, January 12, 2019 - 06:07 AM UTC
What can I say, another excellent job with PE installation. Really enjoying your progress on this build.
Posted: Saturday, January 12, 2019 - 10:59 PM UTC
Nearly ready to cover all that brass with paint, which in some ways is quite a shame.
Appreciate your comments and support along the way.
KitMaker: 2,163 posts
Model Shipwrights: 1,573 posts
Posted: Sunday, January 13, 2019 - 04:24 AM UTC
Your PE work on the hull looks fantastic, but I fear for it as you handle the model as assembly progresses!
Posted: Sunday, January 13, 2019 - 07:44 AM UTC
Thanks Tim,
It is a pay off. I agree there is a risk, the pros are you get a good clean plastic to brass join, and you are not risking the finish by adding the brass onto the painted surface. The con is the risk of knocking bits off.
The other thing, once I have paint on, only pick her up below the waterline!
I do appreciate your concern, the most inporting thing is not be complacent moving the model around.
Thank you again for looking in, and your kind comment.
Posted: Monday, January 14, 2019 - 08:02 AM UTC
This weekend's progress.
Quite a bit of progress too.
Brackets on the walk.
Fitted in place.
Ready for paint.
Primer coat on.
Anti fouling (Tamiya TS33) sprayed, doesn't look a lot different in shade from Halford's red primer.
Whilst this lot is drying, building the other three 3" bow & stern chase guns.
Barbette breakwaters, as moulded.
moulded detail removed, and fitting under way (on the larger forward unit).
The after breakwater completed.
The etched detail added to the forward breakwater, it did have to be annealed to get it bend. That is the discolouration on the brass.
The lower hull masked, ready for spraying.
Sprayed.
along with the 3" guns.
The barbettes and other deck areas not covered by wood sprayed white.
Next jobs, fitting the 3" guns then the maindeck.
Posted: Monday, January 14, 2019 - 01:44 PM UTC
Those 3" guns are looking mighty awesome.
KitMaker: 1,205 posts
Posted: Monday, January 14, 2019 - 06:47 PM UTC
Lovely work on all that P/E Si....Cheers mark
Posted: Monday, January 14, 2019 - 08:52 PM UTC
The are rather nice, it is a pity they will be buried inside the hull.
Posted: Monday, January 14, 2019 - 08:56 PM UTC
The quality and design of the etch has helped an awful lot there. I have gone for the same approach as you are using on your Bismarck build, and likely for the same reason.
Posted: Monday, January 14, 2019 - 09:21 PM UTC
Those tiny guns are awesome! But yeah, they'll be hidden. Does the Admirals walk get a railing?
Posted: Tuesday, January 15, 2019 - 09:15 AM UTC
Hi Gaz,
Yes the admiral's walk will have a railing, that will go a little later. before that the etched wood gratings will have to be painted and fitted.
Posted: Friday, January 18, 2019 - 07:35 AM UTC
The wooden gratings that form the deck of the Admiral's walk sprayed.
The bow and stern chase port hatches sprayed to be fitted in the closed position.
The first of the 3" guns fitted.
On the side with closed ports, the inner of the four part hatch will require ro be posed open, as there is no allowance for the barrel.
The hatches closed, well three out of four isn't bad.
The wood grating fitted and washed, and all around 110 portholes have been glazed with Krystal Klear.
The deck has also been fitted. I did have one small accident, when giving my pot of wash a shake the top leaked, a few splashes all over the quarterdeck. No biggy, they will be covered by the Pontos wood deck.
an overview with the deck fitted.
Wood deck will be next.
Barrovian
KitMaker: 13 posts
Posted: Friday, January 18, 2019 - 08:53 PM UTC
These may be of interest
https://www.nwemail.co.uk/news/barrow/16544976.mikasa-barrows-mighty-japanese-hero/
https://www.nwemail.co.uk/news/barrow/16432697.nostalgia-barrows-famous-vessels-on-display-around-the-world/
https://en.m.wikipedia.org/wiki/List_of_ships_and_submarines_built_in_Barrow-in-Furness
Posted: Friday, January 18, 2019 - 09:39 PM UTC
Thank you Gary,
Of interest indeed, and not just the for the Mikasa build.
Your home town has much to be proud of.
Appreciate your sharing.
Posted: Friday, January 18, 2019 - 11:15 PM UTC
have missed quite a bit of progress on my camping trip with the family: Great amount of progress Si
