Ships by Class/Type: Carriers
Topics on all types of carriers from the early 20th century to today.
IJN Ryujo 1942 - 1/2400 Scale
KitMaker: 1,972 posts
Model Shipwrights: 1,494 posts
Posted: Sunday, November 25, 2018 - 03:42 PM UTC
Painting of the sea base begins with a coat of Tamiya Royal Blue (X-3) acrylic.
The sea received only a thin coating of the blue to keep from obscuring the delicate “wave” patterns stamped on the original paper. I’ll give this a day or two to cure before adding the wake.
KitMaker: 6,395 posts
Posted: Sunday, November 25, 2018 - 10:28 PM UTC
Nice paint job on the sea Tim.
KitMaker: 1,266 posts
Model Shipwrights: 735 posts
Posted: Monday, November 26, 2018 - 12:17 AM UTC
The deep blue of the Pacific ocean, nice choice of color.
KitMaker: 1,635 posts
Model Shipwrights: 1,632 posts
Posted: Monday, November 26, 2018 - 06:09 AM UTC
Yep,
that part of the ocean definitely looks nice!!
KitMaker: 2,877 posts
Model Shipwrights: 2,304 posts
Posted: Monday, November 26, 2018 - 09:54 AM UTC
Just can't get over how small she is!
Posted: Friday, November 30, 2018 - 05:34 AM UTC
Thanks guys. Even though the initial coat on the base was acrylic, I used enamel paints for the wake. Enamels dry more slowly than acrylics, providing more time to work. I also find them easier to blend.
Plus, if I screw things up, the wake can be removed with thinner without damaging the acrylic base coat!
KitMaker: 485 posts
Model Shipwrights: 175 posts
Posted: Friday, November 30, 2018 - 06:07 AM UTC
The ship and base are really looking great. Thanks for your explanations along the way. I learn a lot from watching from afar. Looking forward to more.
KitMaker: 173 posts
Model Shipwrights: 173 posts
Posted: Friday, November 30, 2018 - 06:28 AM UTC
Tim: What type of adhesive will you use to secure the carrier to the base?
Posted: Friday, November 30, 2018 - 06:47 AM UTC
Very subtle work with the wake, looks very much in scale.
Posted: Friday, November 30, 2018 - 08:49 AM UTC
I'll be adding some dabs of Liquitex gloss gel medium to give the wake some dimension; the stuff works great as an adhesive too.
Posted: Friday, December 07, 2018 - 01:54 PM UTC
AAAARRRRRRRGHH!
After getting the satisfactory wake above painting Ryujo’s sea base, I went back to touch it up a little before moving on to the ship... but instead of paint thinner, I inadvertently used lacquer thinner – with HIDEOUS results! The solvent thinned the white enamel paint all right, but it was so “hot” it also attacked the underlying acrylic coat! The blue acrylic paint came apart in revolting, gelatinous sheets... UGH.
Completely unsalvageable, I stripped the whole paint job away down to the primer (which the lacquer had also attacked!)
I’ll have to start again.
Black_sheep
KitMaker: 601 posts
Model Shipwrights: 386 posts
Posted: Friday, December 07, 2018 - 11:27 PM UTC
Oh that is bad luck but these things happened and still happens everyone of us. I do remember one tank model of mine which was painstakingly painted and finished by myself. After everything I just wanted to throw a sealing matt finish over it. At this time I used the matt coat like normal color and then the tank was White... I know you pain
Posted: Saturday, December 08, 2018 - 02:52 PM UTC
Bummer.
Posted: Saturday, December 08, 2018 - 08:55 PM UTC
Bad news Tim,
It is a real pain when something like this goes wrong.
Good luck in the recovery.
Si.
KitMaker: 173 posts
Posted: Sunday, December 09, 2018 - 04:42 AM UTC
Tim: Assuming that you like myself like the little guys as modeling subjects, it is probably not a good time to tell you, given your recent sea base troubles, that Superior is issuing eight new destroyer molds in 1/1200 scale, including three IJN DD's (Kagero, Amagiri, and Yogumo) and five USN including three Fletcher variants,( Square bridge AAA upgrade, Square bridge mid war fit, and Pringle, a round bridge with a seaplane catapult) a Sims, and a Sumner. Each of them with feature new, more accurate, masts, as well as the main gun mounts as parts rather than being molded on, as was the previous practice.
I have not seen these yet, and the information I just gave you is based upon a conversation I had with the owner of Alnavco/Superior, a friend of forty years or more, just last Thursday. More are planned.
The new models are all fresh molds, and will be available after the first of the year. The hull and superstructure molds are already finished, awaiting only the masts and gun mounts. If you are interested I will keep you informed of the progress.
Posted: Sunday, December 09, 2018 - 06:27 AM UTC
Thanks, Chuck, for the heads-up on the upcoming Superior releases. I'll definitely check them out.
And thanks, guys, for the commiserations on my IJN Ryujo woes. I'll get back at it and redo the ocean eventually, but right now I'm so disgusted with myself and that project that I'm going to switch to something else for a while.
Time to peruse the stash...
Posted: Sunday, December 09, 2018 - 09:17 AM UTC
Don't blame you Tim,
I find, when something goes a bit wrong, set the project aside for a bit and the love will come back.
Posted: Sunday, December 09, 2018 - 11:49 PM UTC
Aaargh! I feel your pain Tim!
Choowy
KitMaker: 43 posts
Model Shipwrights: 43 posts
Posted: Tuesday, December 11, 2018 - 05:01 PM UTC
Gee talk about keep us hanging!! Did you break a mirror or something, 2 lots of bad luck with that base.
Hang in there Tim, looking forward to the final result.
LZ32-TX
KitMaker: 34 posts
Model Shipwrights: 28 posts
Posted: Thursday, December 13, 2018 - 10:26 PM UTC
Man that's too bad about the display base, it was coming out pretty well. Hopefully it comes out ok once you decide to come back to it.
Posted: Saturday, December 15, 2018 - 08:33 AM UTC
that's too bad!!!! I can feel your pain, and that you'll set this one aside for a while.
But as I know you, motivation will come back, and I'll still be watching you then!
Posted: Saturday, December 15, 2018 - 12:32 PM UTC
Thanks guys! I don't really have my motivation back for this one, but I've re-sprayed the Royal Blue so at least I don't have to look at that mess of a base any more. Now it is back to uniform blue, waiting for the wake re-do.
It also helped to turn back to the ship itself - shooting some grey did feel like progress!
I intend to depict the ship as she appeared at the time of her loss at the Battle of the Eastern Solomons on August 24, 1942. The real Ryujo had just gone through a yard period from mid-July to mid-August at Kure, so the model was painted in Tamiya Kure Naval Arsenal Gray acrylic (XF-75).
The gray was lightened a bit to adjust for scale effect, and a subsequent coat of Future floor polish acrylic will protect the paint and prep it for the flight deck decal and weathering to come.
Posted: Saturday, December 15, 2018 - 09:16 PM UTC
good to see you're not giving up on this one Tim
Posted: Saturday, December 15, 2018 - 11:22 PM UTC
What Russ said Tim,
Nice to see some progress on this little gem again.
doppelganger
Idaho, United States
KitMaker: 557 posts
Model Shipwrights: 81 posts
Posted: Sunday, December 16, 2018 - 05:04 PM UTC
Catzilla attack on the earlier post? thats funny!
