Constructive Feedback
For in-progress or completed build photos. Give and get contructive feedback!
1/35 Westwal Mg bunkers (sigfried line)
maartenboersma
Noord-Holland, Netherlands
KitMaker: 464 posts
Posted: Thursday, November 30, 2017 - 06:21 AM UTC
Both scratch built from plaster and not weatherd.
Small type:
Medium type:
ColinEdm
KitMaker: 1,031 posts
Posted: Monday, December 04, 2017 - 02:02 AM UTC
Wow, great job Maarten!
maartenboersma
KitMaker: 464 posts
Posted: Tuesday, December 05, 2017 - 11:58 AM UTC
Cheers Colin.
bprice1974
#436
KitMaker: 171 posts
Posted: Tuesday, December 05, 2017 - 01:32 PM UTC
Looking good, I assume you will be adding some figures? What season will you be choosing to go with? A winter scene would look awesome, but so would spring groundwork. How tall and wide is the MG Bunker? Thanks for sharing your work.
maartenboersma
KitMaker: 464 posts
Posted: Wednesday, December 06, 2017 - 07:26 AM UTC
Build these for a fellow model builder.
The first bunker Regelabu C1, approx 9cm x 13cm ,height 10cm
This one of the smallest mg bunkers build.
Second bunker Regelbau 1, approx 16cm x 23 cm ,height 13cm.
Thanks for appreciating my work.
ColinEdm
Posted: Thursday, December 07, 2017 - 02:11 AM UTC
You know Maarten, if you can find a way to make these in sections for easy assembly you could probably sell them.
Kraftstoff
Canada
KitMaker: 91 posts
Posted: Thursday, December 07, 2017 - 09:47 AM UTC
Hey Maarten,
These are really nice...
I bought the Verlinden bunkers way back and these look considerably better.
maartenboersma
KitMaker: 464 posts
Posted: Thursday, December 07, 2017 - 11:22 AM UTC
I do sell them ....all tops are removable so they can be furnished and all the rooms and doors and al the other things are in place exept th plumbing.
The people that are into model 1/35 bunkers know me well here in the Netherlands and some in germany.
maartenboersma
KitMaker: 464 posts
Posted: Thursday, December 07, 2017 - 11:27 AM UTC
Hey Maarten,
Hi dave,
He was the main reason for me to make my own,because his bunkers are pure fantasy and way to small in size and roof/wall thickness
Maarten.
maartenboersma
KitMaker: 464 posts
Posted: Thursday, December 07, 2017 - 11:36 AM UTC
Here you can follow my current bunker build,but beware it is BIG!
http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=263944&page=1
Some more of my Bunkers
https://gallery3.kitmaker.net/useralbums.php?ppaction=albums
sgtreef
Oklahoma, United States
KitMaker: 5,791 posts
Model Shipwrights: 15 posts
Posted: Thursday, December 07, 2017 - 12:18 PM UTC
Nice job, well done.
I do like them big bunkers.
I wanted to do one for my 1/6 scale Flak, but after looking at the size, said not in this life.
Maybe you could mold it up and sell it?
Might I ask what color for the concrete used?
I just cast a base in plaster for the M-110 I am making and put in some Poster dry pigment black , well after 3 times I am still out on the concrete color, and the bigger one looks to be a slight different color.
Sean50
Manche, France
KitMaker: 243 posts
Posted: Thursday, December 07, 2017 - 05:40 PM UTC
Hello Maarten
These are excellent. Amongst the best bunkers I've seen in miniature.
Did you make a mould and pour the plaster, kind of like the originals? If so is it solid or did you use a lighter material to bulk out the walls?
I ask because I have a similar project in the queue.....
Removed by original poster on 12/08/17 - 04:41:59 (GMT).
maartenboersma
KitMaker: 464 posts
Posted: Thursday, December 07, 2017 - 11:43 PM UTC
Hi Jeff,
I have no strict concrete mix color,except it has to be matt acrylic paint so it can suck up all the washes.
The main colors are white ,black to make a light grey and some german yellow to give it a bit of a creamy grey color and the rest is weathering
Best advise is look at real concrete there many shades
https://www.google.nl/search?hl=nl&biw=1904&bih=932&tbm=isch&sa=1&ei=S3kqWrOjLMbLwQKP5IjgBw&q=concrete&oq=concrete&gs_l=psy-ab.3..0i67k1l2j0l3j0i67k1j0l2j0i67k1j0.20500.23686.0.24214.8.6.0.2.2.0.95.433.6.6.0....0...1c.1.64.psy-ab..0.8.470....0.YfFcWbebjCA
If its for a FLAK 38,it can be a nice garden feature
You can scale it from this a simple square one.
https://3dwarehouse.sketchup.com/model/f6990ed1e3035347542d11b0ddf4bb07/Gesch%C3%BCtzstand-f%C3%BCr-2-cm-FlaK-38
maartenboersma
KitMaker: 464 posts
Posted: Friday, December 08, 2017 - 12:00 AM UTC
Hello Maarten
Bonjour Sean,
Yes just like the real ones only smaller and with plastic instead of wood,
The wood planking i simulate by scratching th plastic sheets,always use two or 3 differnt thickneses other wise it looks to flat i use 0.5mm 075mm and 1mm
On pictures the bunker might look smooth but there ain't as you probably already know ....your country is full of (which is nice)
Pic below is real bunker texture
And this is my 1/35 bunker texture
I think it looks good.
I use special pouring plaster you can buy in artistic shops,
If the walls are going to be to thick i fill it up with some styropor/insulation/foam, board you get at the hardware stores.
Be sure you glue it securely to your base otherwise it will float up when you pour your plaster (wich is a pain in the @##$$ when it happens)
Love to see your work i never seen any other scale bunkers being made (the way i like it ) you can PM any time.
Maarten.
Sean50
Manche, France
KitMaker: 243 posts
Posted: Friday, December 08, 2017 - 09:41 PM UTC
Thanks Maarten,
Yes, there are one or two bunkers here in Normandy (and France generally)... it's almost as if the Germans didn't want anyone to invade
Good tip re gluing the foam to the base. That's just the kind of thing I forget to do
I have a couple of other things on the go at the moment and really need to clear some space before I start with the fortifications.... they take up some space as you know.
Thanks again for the description and illustrations.
sgtreef
Posted: Saturday, December 09, 2017 - 02:03 AM UTC
Hi Jeff,
Thanks a bunch I will make up some pours and put up on here, maybe you can give some insight to them.
Jeff
